FridgeFreezer Posted August 5, 2014 Share Posted August 5, 2014 Having googled and turned up nothing useful, I'm more after pictures/diagrams showing how they're made what with the extra rear overhang and all, but part numbers would also likely help with the research. Quote Link to comment Share on other sites More sharing options...
western Posted August 5, 2014 Share Posted August 5, 2014 Look under 110 hi cap, there's a extension box like block fits between rear crossmember & hitch ladder frame Like the lower diagram herehttp://lrcat.com/#31/4/52555 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 5, 2014 Author Share Posted August 5, 2014 Cheers Ralph, high tech solution then! Quote Link to comment Share on other sites More sharing options...
western Posted August 5, 2014 Share Posted August 5, 2014 Simple but does the job ? Quote Link to comment Share on other sites More sharing options...
bodumatau Posted January 24, 2015 Share Posted January 24, 2015 Just a tip freezer, if your 130 has done any hard work you will find the rear mounting brackets for the load bin are poked, or busy trying to die. A bit of flatbar welded on top of the tow bar extension which bolts into the Ali angle iron edge that runs across the back of your loadbin makes these brackets last a LOT longer. In fact on mine I have built a steel rear bumper which bolts into the mounting holes for the loadbin, put tubes (pieces of 20mm sqr tube ) inside the chassis so it doesn't compress the chassis and loosen when tightening. Then across the top of this steel bumper made new mountings for the loadbin. Works much better. Quote Link to comment Share on other sites More sharing options...
