300 series Disco eyebrows
MogLite
You might be lucky but the glue they use to stick most of those eyebrows on sticks like sh** to a blanket! Not sure if that particular type is glued or sticky-back but I think they are glued. You may get them off ok but whether you would get the glue off without wrecking the paint would be the problem I think.
They are all one piece with the side trims, when you fit those "wheelarch moulding" types, you take off the original side trim strips and fit the whole new trims. Best bet might be to take the whole thing off and get a set of the original trim strips?
