heater fan
discojoe
Maybe check the feed hasn't gone to ground for some reason (chaffed or trapped). Other possibility is the fan has seized, don't know what you do with your Disco but if you go wading and start puling mud and water through the heater is doesn't do the fan bearings any good.
to get the fan motor out you need to get inside the heater box. to get to the heater box you need to remove the dash. when i ripped my heater apart to find why it didnt work it took about 4 hours to get the dash out, strip the heater & find no faults - trace wiring & discover the relays in the drivers kick panel, curse a lot & refit everything.
