Retroanaconda Posted January 13, 2015 Share Posted January 13, 2015 Sorry Ben, I'm not sure where you're referring to - could you mark it on the photo? That pic is of the frames in my shed that I photographed for you before I think. So I can get any necessary measurement off that if need be. Quote Link to comment Share on other sites More sharing options...
Ben Spray Posted January 14, 2015 Author Share Posted January 14, 2015 ah yes I should have looked back at the start of this thread, I'd saved the pictures but couldn't remember where from - doh anyway the square hole in the circled area is for the saddle type thing to clip into to hold a clip on the loom, no idea what the 3 other holes are for but if you get a chance to measure at some stage at least I can add them if I find out what they are for Thanks Ben Quote Link to comment Share on other sites More sharing options...
wanger Posted January 14, 2015 Share Posted January 14, 2015 i'd galv them. they are right in the firing line of the rear wheel. They will bow a little but straighten easily enough theyre a fortune and need protecting Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 14, 2015 Share Posted January 14, 2015 Will get some measurements for you ASAP Ben. Quote Link to comment Share on other sites More sharing options...
Ben Spray Posted January 14, 2015 Author Share Posted January 14, 2015 Great thanks No rush, as I have a few other issues to deal with that I've only just spotted the strengtheners in place for the lift up door style latches are right in the way of where the nut plates need to be for the push button door style latches, not too sure how to get around that yet, looks like I may have to cut the spot welds out and shift them up a bit and re weld back into place.... more work..... Thanks Ben Quote Link to comment Share on other sites More sharing options...
Ben Spray Posted February 17, 2015 Author Share Posted February 17, 2015 Hi James Any luck Cheers Ben Quote Link to comment Share on other sites More sharing options...
western Posted February 17, 2015 Share Posted February 17, 2015 Can I ask an ignorant question ..... Why are they £700 ? cost of the side frames & cost of the process to galv them, manhours to get it all sorted, you'd want that sort of money for all the effort. brand new from LR each side is Left hand side http://www.brit-car.co.uk/product.php/138903/0/body_side_frame_assy_lh_110_def_7a_ Right hand side http://www.brit-car.co.uk/product.php/138902/0/body_side_frame_assy_rh_110_def_7a_ Note the price difference Quote Link to comment Share on other sites More sharing options...
wanger Posted February 17, 2015 Share Posted February 17, 2015 thats a good site. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 17, 2015 Share Posted February 17, 2015 Hi Ben Apologies for the delay, slipped my mind again. I swear the holes in the sieve are getting bigger... Anyway. The square hole: - Measures 12 x 7 mm - Sits approx. 14 mm from the forward edge of the pillar. - Sits approx 55 mm below the bottom of the oval hole. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Ben Spray Posted February 17, 2015 Author Share Posted February 17, 2015 Great thanks James, what sizes are the 3 little round holes (not sure what these are for but may as well drill them ) Thanks Ben Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 19, 2015 Share Posted February 19, 2015 About 6mm Ben, no idea what they are for either. Lightening attempt perhaps Quote Link to comment Share on other sites More sharing options...
western Posted February 19, 2015 Share Posted February 19, 2015 possibly tooling holes so the material is correctly aligned in the press before forming the B post section. Quote Link to comment Share on other sites More sharing options...
Ben Spray Posted February 19, 2015 Author Share Posted February 19, 2015 Cheers James, I may have to poke around a few higher spec vehicles/image search on google etc and see if I can see anything actually using those holes! I now have the aux loom (YMM000341 / lr016438) which runs under the seatbox and up the B pillars and clips into that little square hole before plugging into the rear door looms so will need that hole at least ps if you need that loom keith gott has them for £15 + vat (list is about £70 + vat)!! Thanks Ben Quote Link to comment Share on other sites More sharing options...
