Fatboy Posted November 10, 2014 Share Posted November 10, 2014 The vehicle is a 2002, Range Rover l322 with the 4.4 V8 BMW M62 Engine. (VIN SALLMAMA32A1107XX). I need a replacement screw on cap for the radiator expansion tank on the LH inner wing. Our local garage has searched his catalogues and can only find PCD000070 which is a cap with "140" on it. My vehicle has a cap with "200" on it (and the O ring retaining housing is breaking up, thus it needs replaced. If I fit the "140", it pours out water when getting up to temp.... Thanks for any help! Donald Quote Link to comment Share on other sites More sharing options...
western Posted November 10, 2014 Share Posted November 10, 2014 found this one PCD000090G http://www.roverparts.com/Parts/PCD000090G don't know the L322 RR very well, so not sure if it's the cap your after also found this one LR017427 but cannot find a photo of it on internet. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 10, 2014 Author Share Posted November 10, 2014 Thanks Ralph, It's not the first one, I'll try and find a pic of the 2nd one .. Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted November 11, 2014 Share Posted November 11, 2014 The cooling system on a L322 is suppose to have the "140" or 1.40Bar cap on it. The workshop manual recomends it. You may have a concern that was conseled with the 2.0 bar cap. The 2.0 bar cap was a BMW part from BMW not Land Rover. 1 Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 12, 2014 Author Share Posted November 12, 2014 Ahhhh..... Maybe I should run it with the 140 cap and see where the water level ends up. However, I suspect it will go below the sensor in the header tank.. Or maybe I'll head to the BMW garage for a new 200. Thanks gents! Quote Link to comment Share on other sites More sharing options...
Fatboy Posted July 16, 2015 Author Share Posted July 16, 2015 So, to close this one out. I fitted the 140 cap and all has been almost fine. Header tank split a couple of weeks ago but I'm fairly sure it was the original, and its now done almost 160k miles so not too bad. Goodness knows where the 200 cap came from but its now been binned. Thanks for the help.. Quote Link to comment Share on other sites More sharing options...
