Defender (MOD 110 FFR) Weight
Taffia
Hi,
Quick question - a friend of mine pointed out that the information plate under the bonnet on the drivers side has the following numbers under each other:
3050KG
5550KG
1 - 1200KG
2 - 1850KG
Its a 95 110 Ex MOD FFR Canvas - does the above mean its 3.05 tonne in weight and does that mean a different MOT class?
I have had a look around and can't see anything. Its not a Snatch vehicle I can't work it out as I though it was closer to 2T (1850KG)
Thanks for your input - just don't want to get caught out!
Taffia
If I remember correctly:
Gross vehicle weight(max fully loaded)
Gross train weight(max including trailer)
front axle (max load)
Rear axle (max load)
Technically it should be class 7 MOT(van) but seems to depend on tester.
Mike
Thanks
Is this considerably heavier to a normal 2 door 110 then?
I appreciate it may be down to the Tester but if there was an insurance query etc could I fall back on the MOT was done as X?
I don't look good in Orange!
Taffia!
heavier because the military chassis maybe the heavy duty type, plated top & bottom of the main rails, should be easy to see, plus heavy duty suspension, which would give a higher gross loaded vehicle weight over a civilian 110 of the same body/tilt type.
a current MOT shouldn't cause any insurance problems.
