Paulpen Posted November 20, 2014 Share Posted November 20, 2014 Hi guys - popping in for a friend again :oops:Popped round to see his 2000 90 TD5 as he was having intermittant non start issues.When it does not start there is just a loud clonk noise from the starter motor so im assuning it having internal issues.Its getting a solid battery voltage to the main stud and hitting it with a hammer seems to have no effect.Thought id try and undo the 13mm nut to clean the connections up but seems that the stud all the wires mount to wants to trun on its own and guessing it should not do this. Having done this it then started everytime so guessing this is the issue rather than the starter itself ?If so is it something that can be fixed ? I get the feeling that trying to undo the nut fully will either snal the stud off or its just going to spin so something will need cutting off Is it a replaceable part and has anyone delt with this before as we would rather have a plan of attack rather than break it and then decide what to do Quote Link to comment Share on other sites More sharing options...
missingsid Posted November 21, 2014 Share Posted November 21, 2014 I know you want expert info but whilst waiting for that I found this ebay listing, is this the starter you have? If nothing else it gives you a view of the inside? Marc Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted November 21, 2014 Share Posted November 21, 2014 You can buy a rebuild kit which includes new copper contacts which may have worn out. http://www.ebay.co.uk/itm/LANDROVER-DISCOVERY-TD5-DIESEL-FULL-STARTER-SOLENOID-KIT-C-W-SPRING-BOLTS-etc-/291196737071?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43ccad962f That's what I did with mine and I even had the whole starter motor apart too. Steve Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted November 21, 2014 Share Posted November 21, 2014 Here in Colombia you can buy a Toyota starter and simply change the conection pinnion. It costs like 1/3 of the Land Rover one..... Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted November 23, 2014 Share Posted November 23, 2014 The contacts wear out, as above the eBay kit is cheap and easy to fit, even I managed it without setting fire to anything, the other thing to check is that the switch wire isn't loose, mine was and needed a new crimp terminal on it Mike Quote Link to comment Share on other sites More sharing options...
Paulpen Posted November 26, 2014 Author Share Posted November 26, 2014 Ta for all the advice After running through it all with him speed was of the essence as he was losing money daily due to it not starting at all now.He managed to collect a new starter from Devon4x4 so thats been fitted and we will rebuild the old one and keep as a spare when we have some spare time Quote Link to comment Share on other sites More sharing options...
