T1G UP Posted November 2, 2006 Share Posted November 2, 2006 bought a v8 bob and its on carbs. any helpfull hints and tips on carbs.how to adjust. the miture atc will it run ok on unleaded. whats the oil about in the carb. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 2, 2006 Share Posted November 2, 2006 Unleaded would be down to ignition timing (distributor) not carbs. Oil in the carb is the damper thingummy, errr, that's as much as I know about them horrible clockwork things... yuck Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 2, 2006 Share Posted November 2, 2006 Unleaded would be down to ignition timing (distributor) not carbs. Oil in the carb is the damper thingummy, errr, that's as much as I know about them horrible clockwork things... yuck All rover V8s can run unleaded, back timing off a tad if it pinks. engine oil goes in them to a set level this damps the piston inside the carn unit, both on strombergs and SUs. Prob worth you getting a ahynes manual and having a read for basic servicing and ownership knowledge, etc, or you can always ask here I guess !! Nige Quote Link to comment Share on other sites More sharing options...
