Frax Posted February 1, 2015 Author Share Posted February 1, 2015 Went for a 40 mile run today and at the end I had this Saying that on the way home at one point the gauge did go up to about the 10 30 point but it was only for about 1 min then went back to where it was. Anyway going to change it. Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2015 Share Posted February 1, 2015 reckon you have a airlock in the heater matrix. Quote Link to comment Share on other sites More sharing options...
Frax Posted February 1, 2015 Author Share Posted February 1, 2015 Will need to look at that Western, would a good flush through the heater with a garden hose clear that out. I will have to drop the coolant level to change the stat anyway. Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2015 Share Posted February 1, 2015 Yes purging the heater with a hose will make sure it's full of water, Quote Link to comment Share on other sites More sharing options...
Frax Posted February 6, 2015 Author Share Posted February 6, 2015 Well the stat turned up at long last - only 5 days late Just fitted it and was going to test my old one but there was no point, the only desaster I had was that stupid plastic plug. The top of it snapped off just above the thread but I was able to remove the threaded part. Luck for me I had a steel plug that fitted, if anyone has the part number for the plastic plug let me know as the steel one will react. Now back to the stat - this is what I found. About 1/4 of the seal had gone - hope you can see it in the picture. Quote Link to comment Share on other sites More sharing options...
western Posted February 6, 2015 Share Posted February 6, 2015 stat housing plug get one of X-eng's red or blue alloy ones http://foundry4x4.co.uk/index.php?route=product/category&path=65_1758 Quote Link to comment Share on other sites More sharing options...
Frax Posted February 6, 2015 Author Share Posted February 6, 2015 Thanks Western - will order two as the radiator one left a while back, the plastic is not the best. 1 Quote Link to comment Share on other sites More sharing options...
Souster Posted February 7, 2015 Share Posted February 7, 2015 I've got brass ones in mine that are considerably cheaper than the X eng ones if your not bothered about bling Quote Link to comment Share on other sites More sharing options...
Frax Posted February 7, 2015 Author Share Posted February 7, 2015 X Eng plugs ordered now and they did cost a bit more than expected but hope I only need to order tham once. Quote Link to comment Share on other sites More sharing options...
western Posted February 7, 2015 Share Posted February 7, 2015 had mine for ages, not had any problem with it, fit a O ring rubber seal to both when you get them. Quote Link to comment Share on other sites More sharing options...
Frax Posted February 8, 2015 Author Share Posted February 8, 2015 Was out last night and only did about 5 miles and got this All looking good now so should be a bit warmer when I go for a good drive about. Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2015 Share Posted February 8, 2015 that looks a lot better, about the same position as my 200tdi temp sits, next is sort the heater cables & you'll be toasty in there. Quote Link to comment Share on other sites More sharing options...
bodumatau Posted February 8, 2015 Share Posted February 8, 2015 What's the job of the little one way valve thingy in the thermostat ? Is it to bleed air out of the system? That why it needs to be at the top? Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2015 Share Posted February 8, 2015 jiggle pin to allow some coolant to leak past & any trapped air to escape to header tank. My thermostat has a jiggle pin ??Yes. Many thermostats have a “jiggle pin” that allows trapped air in the cooling system to pass through the thermostat and be released from the system. Some Stant thermostat do not use have a jiggle pin. These thermostats will have a "bleed notch” or other method of removing air from the system. from http://ww2.stant.com/Consumer-Products/FAQs/#anchor15 Quote Link to comment Share on other sites More sharing options...
Frax Posted February 8, 2015 Author Share Posted February 8, 2015 Heater set up Western as per your instruction - Thank you. 1 Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2015 Share Posted February 8, 2015 I'm sure you won't be cold Quote Link to comment Share on other sites More sharing options...
