1990 110 ex-MOD seats
land_rover_one_ten
So I have just acquired a 1990 110 V8.
I want to replace the seat backs / bases in the cab as they are split / worn.
It currently has two seats in the cab the drivers is adjustable, the passenger seat is attached to the bulkhead.
The frames are fine it is just the backs / bases I need.
Am I right in thinking I need series seat back / base like these one?
http://www.ebay.co.uk/itm/LAND-ROVER-SERIES-2-3-STANDARD-BLACK-VINYL-SEAT-BACK-/370530886379?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item56455ca2eb
http://www.ebay.co.uk/itm/LAND-ROVER-SERIES-2-3-STANDARD-BLACK-VINYL-SEAT-BASE-/220778607044?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item33676e31c4
I also want to fit a matching middle seat.
Does anyone know what is required and which parts I need?
You've found the right parts - use series seat bases and backs.
The bases drop right into the frame, backs are attached with two small bolts each side.
You can also use the 'deluxe' seats and there is a high back version as well.
if you fit centre seat you'll need a seat frame first. Island 4x4 are good for the seats (from £18 each & free delivery if you order a set) & do a package of all three fronts.
  • 2 weeks later...
