Anderzander Posted February 7, 2015 Share Posted February 7, 2015 I've some of these kind of chunky crimps ..... On say a 35mm terminal would you need to do a sequence of crimps ? I watched a YouTube video that said they have a narrow crimp area - so you should start close the terminal and work your way back to the cable end. Is that how everyone does it ? I know the hydraulic ones seem to have a broader crimp ... ? Quote Link to comment Share on other sites More sharing options...
stuck Posted February 7, 2015 Share Posted February 7, 2015 I've never needed to crimp more than once on flexible cables such as you'd use for a winch. Put some heat shrink on the cable 1st then slide over the lug & shrink, looks much neater Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 7, 2015 Author Share Posted February 7, 2015 Thank you Quote Link to comment Share on other sites More sharing options...
SPendrey Posted February 7, 2015 Share Posted February 7, 2015 I've got a pair of those too, I tend to go for one size below what looks right, and squeeze like hell! LIkewise, heat/shrink wrap makes things look tidy after too. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 10, 2015 Share Posted February 10, 2015 I brought a 7ton hydraulic crimp it is one of the best bits of kit I brought and has never let me down. Jason. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 10, 2015 Share Posted February 10, 2015 Choose the right size for the appropriate crimp and cable diameter. Going smaller is likely to break the copper strands. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 10, 2015 Author Share Posted February 10, 2015 Good info on the first half of this video here ... Mine are done now - I did a double crimp on each one as they suggest in the video. Quote Link to comment Share on other sites More sharing options...
