western Posted November 6, 2006 Share Posted November 6, 2006 (edited) have a look if your after one of these GKN-overdrive not mine Edited November 6, 2006 by western Quote Link to comment Share on other sites More sharing options...
jjojjas Posted November 8, 2006 Share Posted November 8, 2006 Just in case anyone else is interested in this. I'm after an O/D so I looked into it. I called GKN with the serial number. It's a "very old model" that you can't get the output gear for any more so you must replace the whole output end at just over £200. The speed sensor is £50 and the seals are a quid each. So essentially its £250+ to get the thing ready for a 1.4:1 transfer box...and then it may still be on its way out.... god knows what it reaches in the auction on top of that. they appear to be like hens teeth...... Jas Quote Link to comment Share on other sites More sharing options...
TJ101 Posted November 8, 2006 Share Posted November 8, 2006 Yep,, also seen that one, as a overdrive is needed down here sometime as well, Quote Link to comment Share on other sites More sharing options...
G4FUJ Posted November 9, 2006 Share Posted November 9, 2006 Ralph, Do you find the O/D a great advantage with the Tdi? Did you change the transfer box / high range gears when you junked the 19J? Cheers, Quote Link to comment Share on other sites More sharing options...
western Posted November 9, 2006 Author Share Posted November 9, 2006 Ralph,Do you find the O/D a great advantage with the Tdi? Did you change the transfer box / high range gears when you junked the 19J? Cheers, OD makes long journey's quieter, it drop the revs by about 600 at 60mph, transfer gears are exactly as per the old 19J engine, no change from a factory built 200Tdi, main gearbox has same ratio's too. Quote Link to comment Share on other sites More sharing options...
