Truck cab rear window rattle
On the Def 110SW sliding rear side windows a permanent anti rattle cure is to open the window, put some silicone sealant in the vertical channel on the 'open' end, shut the window into the sealant, and then force the two panes of glass apart with a little wooden wedge and fill up between the two panes of glass with silicone too, leaving it to set for 24hrs before pulling out the wedge. Never fails to cure a rattle, window won't open afterwards but nobody ever uses them anyway so not a problem!
