Lt77 range rover and 200tdi defender differences?
reb78
Defender is slightly different ratios I believe lower. Range rover has the longer bell housing as does the disco also the V8 has a different input shaft (spigot bush is smaller though you can get a bush to match V8 box to a diesel).
Rangie box doesn't fit a defender without work (done to death on here).
Mike
Dunsfold have some new ones (not recon) for sale Dave. I was pondering going that way instead of another recon that would last less time than it should... Might be harder work than I'd hoped though....
