bodumatau Posted June 2, 2015 Share Posted June 2, 2015 so my td5 crew cab seems to always be very unresponsive when i start her up in the morning almost as if she doesn't have a turbo (which points me toward the airflow sensor) and then after irritating me sufficiently (after 2-3 minutes) she starts pulling nicely. any tips or ideas where to look to start fixing this? 2001 Td5 EGR has been bypassed everything else pretty standard. Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 2, 2015 Share Posted June 2, 2015 Unplug the MAF and see if this solves the issue. If it does, replace the MAF. This is the best price i have found for VDO (OEM) MAFs - http://www.island-4x4.co.uk/flow-sensor-mhk100620g-p-3943.html I had similar problems when my injector seals went on the D2 - this was combined with a faulty MAF in my case. Quote Link to comment Share on other sites More sharing options...
vinny Posted June 2, 2015 Share Posted June 2, 2015 Had the same problem with my td5 new vdo maf sorted it Quote Link to comment Share on other sites More sharing options...
dantastic Posted June 8, 2015 Share Posted June 8, 2015 Before running out and buying a new part you can try cleaning it. Spray it with brake cleaner, let dry and re fit. These get dirty over time and need cleaning on a regular basis. Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 8, 2015 Share Posted June 8, 2015 Before running out and buying a new part you can try cleaning it. Spray it with brake cleaner, let dry and re fit. These get dirty over time and need cleaning on a regular basis. There are a lot of posts out there that suggest cleaning damages them. If broken already you have nothing to lose, but I wouldn't touch one without a problem for fear of causing one. Quote Link to comment Share on other sites More sharing options...
dantastic Posted June 8, 2015 Share Posted June 8, 2015 Don't get me wrong, the business end of the MAF sensor is extremely fragile. In most cases all it need is to be cleaned but if you break it then... well... Quote Link to comment Share on other sites More sharing options...
