cypermethrin Posted February 12, 2016 Share Posted February 12, 2016 I know this is a topical question and the symptoms are side light and full main beam work fine. But switching small light switch stalk to have the headlights on results in nothing - even the dash indicator for the lights goes out I know 1/ its not the Pink relay behind the dash 2/ its not the relay in tge fuse panel behind the gearstick 3/all fuses good So its down to either the long indicator stalk or the smaller light switch stalk ? I presume its more likely to be the indicator stalk rather than the sidelight/headlight switch but how can I tell which is duff ? Thanks in advance for your counsel Quote Link to comment Share on other sites More sharing options...
Aragorn Posted February 12, 2016 Share Posted February 12, 2016 I think given the sidelights go out, its gorra be the light switch. Only the dip beam passes thru the indicator stalk? Quote Link to comment Share on other sites More sharing options...
western Posted February 12, 2016 Share Posted February 12, 2016 the main light switch [short stalk on left of column surround] is side/tail lights & dipped headlights, as your side/tail lights go out & dipped headlights don't come on, then it's has to be a faulty main light switch, the indicator/horn/main beam from dip & flash stalk is working & doesn't switch the normal dipped headlights on or off. Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted February 12, 2016 Author Share Posted February 12, 2016 Thanks guys ..... You are right changed the indicator stalk...... Same problem.....so definately the main light switch.... 1 Quote Link to comment Share on other sites More sharing options...
