Rear prop length
Yeh I guessed the rear would be too long but it Says on the thread above that my rear one is 667 and a disco front one is 637. Was hoping I could catch a break somewhere with it to get it back on the road asap but i guess not. Not too keen on diff lock and front wheels only
Front props are phased differently to rears. Rears are normally in line fronts are one or two splines off in line. You can Re phase them but obviously not if it's to short.
If it makes you feel better I had a drum fall off the same way but I ran it over so stop to pick it up. Now I whined the nuts back on as well as the areas.
Mike
