Rear prop shaft on new axle fitted to older defender
Ok hopefully my last rebuild question. I bought from a breakers yard an excellent quality complete rear axle off a 2014 defender. I am fitting it to my 97 110 defender. I'm aware that the later axles has the rover not Salisbury diff. What rear prop shaft do I need. I'm guessing the latest defenders with the Ford engine don't use an R380 gearbox. But surely in the time between there was a prop shaft for the R380 connecting to the later non-Salisbury axle? Part number or years for which the correct shaft I need?
Cheers as always
