Repair or Sell as, help please 300tdi
Its even easier than that - You only need a valve compressor if you plan to take the valves out. You don't need to do that if you are just changing the gasket.
Very true but I really cannot justify doing all that work and not change the valve guide seals and lap the valves in while I'm at it.
Hopefully this will help to give you confidence that this job is well within the scope of the average DIYer. People have mentioned videos on youtube, trailerfitter does some really good videos showing you how - he even has one on this very topic, and you can see the head on a 300Tdi isn't a heavy to lift as you might think.
The only parts this video doesn't show is you have to drain the coolant, remove the injector pipes, take the feed wire off from the 4th glow plug (nearest the bulkhead), remove inlet and exhaust manifolds, take off the oil feed pipe at the back of the head, and then the rocker cover off (don't think I've missed anything?)- all easy jobs!
The next video after it covers putting the head back on again.
Tempted yet?
  • 4 weeks later...
