reb78 Posted June 20, 2016 Share Posted June 20, 2016 I fitted a genuine new hub to the d2 yesterday and it failed on the test drive, 5 mins in, squealing, three amigos on, nanocom saying sensor reading low and intermittent. It looks like the outer bearing has overheated as the hub body is blue all around the outer edge. I followed urban panzers online guide to the letter http://www.discovery2.co.uk/fronthub.html All torque settings were correct (including the 490nm on the stake nut). What could i have done to cause this during fitting? I put the old hub back on for the time being, and thats ok for now (was trying to perform preventative maintenance as the old one has a little noticeable play in it but as yet hasnt caused any issues) Quote Link to comment Share on other sites More sharing options...
Tal Posted July 4, 2016 Share Posted July 4, 2016 The only reason for a bearing to get that hot is severe friction, so its either lack of lubricant or a massive bearing failure or both. I don't know if you can grease the D2 bearings yourself or they are a completely sealed unit but it sounds like you are due a replacement to me. Quote Link to comment Share on other sites More sharing options...
BennehBoy Posted July 5, 2016 Share Posted July 5, 2016 They're a sealed unit. I'm guessing it was a 50 quid ebay job? Get a replacement, and try avoid those in future. Genuine are now ~ 400 quid so really not worth fitting. Timken who made the OEM units have stopped making these, but some places still have a few in stock at about 250 quid. Britpart do an 'oem' one for about 150 and tbh I've only heard good things about them. Most of the chinese knock off ones (and also bearmach ones btw) have only 55 teeth on the reluctor rings instead of 60 and cause havoc with the ABS/TC, so avoid if not fitting in matched pairs/all four. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 5, 2016 Share Posted July 5, 2016 Fourth word reads 'genuine' 1 Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 5, 2016 Share Posted July 5, 2016 Could be a manufacturing fault. Some years ago Bearmach had a bad stock of clutch thrust bearings with no grease in them. Les. Quote Link to comment Share on other sites More sharing options...
BennehBoy Posted July 5, 2016 Share Posted July 5, 2016 Fourth word reads 'genuine' Wish my brain was Quote Link to comment Share on other sites More sharing options...
