mcc1979ian Posted July 10, 2016 Share Posted July 10, 2016 Went to bleed my clutch today but no matter how many times we pump the pedal no fluid comes out the slave cylinder. Is there a specific way of bleeding it or do we reckon my clutch servos gone? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted July 10, 2016 Share Posted July 10, 2016 The clutch doesn't normally have a servo but it should bleed up even if it does and it's knackered. Crack each joint one at a time starting at the master pumping each time if you get fluid move on if not there's your problem. Mike Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted July 10, 2016 Author Share Posted July 10, 2016 Found a crush in the pipe so changed it. Still won't bleed Quote Link to comment Share on other sites More sharing options...
western Posted July 10, 2016 Share Posted July 10, 2016 is the slave cylinder bleed screw uppermost with the pipe connection below ? try disconnecting the pipe from slave cylinder to see if you can pump fluid through the pipeline run, if OK the bleed screw bleed holes could be blocked up, clean them out with a small drill bit /piece of stiff wire. Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted July 10, 2016 Share Posted July 10, 2016 you could try reverse bleeding it. get an oil can and fill it with brake fluid. put a hose on the end and connect it to the bleed nipple. open the nipple and pump slowly. if theres air in there it should travel up to the master cylinder. a standard oil can should hold enough to do the job. make sure there/s room in the master to receive the fluid. obviously the bleed nipple must be checked / cleared first as Western says. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted July 10, 2016 Author Share Posted July 10, 2016 Nipple is uppermost, tried reverse bleeding and ended up with black sludge flowing into the bottle. Now there's nothing coming out at all. If I blow the airline up from the slave there's bubbles in the reservoir so I'm assuming it's all clear. For the sake of £20 I'll change the master cylinder and see if that cures it. Quote Link to comment Share on other sites More sharing options...
western Posted July 10, 2016 Share Posted July 10, 2016 black sludge sounds like the seals have or are past their best, maybe part of the seal has blocked the pipeline bore. if replacing the master, it's worth doing the slave as well. Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted July 10, 2016 Share Posted July 10, 2016 i agree. might as well do them both at the same time. hopefully once they've both been changed and bled, you wont have to visit them for some time, famous last words. Quote Link to comment Share on other sites More sharing options...
