unfit Posted August 12, 2016 Share Posted August 12, 2016 Hi I have a defender 90 tdi 300 n reg, with a broken rear tail pipe and silencer. The silencer and pipe unit is I think esr3463. I would like to the esr4527 instead. This is because it is a cheaper part, as well as being not silenced. As my tdi300 is a quiet run I don't think it will be too loud!!. Has anyone done this or has knowledge that the two parts are both a correct fit for my model? Cheers Quote Link to comment Share on other sites More sharing options...
western Posted August 12, 2016 Share Posted August 12, 2016 esr3463 ----- http://www.paddockspares.com/esr3463-rear-tailpipe-and-silencer-90-300tdi-1995-1997.html esr4527 ----- http://www.paddockspares.com/esr4527-rear-tailpipe-90-300tdi-from-ta999222-to-wa159806.html provided the attachment points are the same it should fit. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted August 12, 2016 Share Posted August 12, 2016 Esr4527 has to be used with esr4526 mid pipe silencer. It will not fit with the mid pipe used with esr3463. The joints are in the wrong place. Esr4526/4527 also requires a different mount which bolts to the aframe crossmember. Quote Link to comment Share on other sites More sharing options...
