Les Henson Posted November 30, 2006 Share Posted November 30, 2006 UJ is Universal joint, and there's one at each enf of the prop (usually), they permit continued drive from the transfer case to the axle/s regardless of suspension position. If you have non-sealed type, thene there will be a grease nipple on each UJ, and then anothjer for the sliding joint. Picture of UJ, and it's location:- Les. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted November 30, 2006 Share Posted November 30, 2006 They sell engine oils in any OBI which you will find in all big towns (orange writing). It is mainly a DIY superstore but they have quite a big selection of basic auto maintenance stuff too. So long as you know the SAE you want (10/40??) then you will be able to pick up an oil. They certainly sell Castrol there so play it safe and buy that Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 30, 2006 Author Share Posted November 30, 2006 UJ is Universal joint, and there's one at each enf of the prop (usually), they permit continued drive from the transfer case to the axle/s regardless of suspension position.If you have non-sealed type, thene there will be a grease nipple on each UJ, and then anothjer for the sliding joint. Picture of UJ, and it's location:- Les. So, I have greased one UJ and one sliding joint at the front end of the propshaft. I will do the back section this weekend. Thanks for your help. Paul. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 30, 2006 Author Share Posted November 30, 2006 They sell engine oils in any OBI which you will find in all big towns (orange writing). It is mainly a DIY superstore but they have quite a big selection of basic auto maintenance stuff too. So long as you know the SAE you want (10/40??) then you will be able to pick up an oil. They certainly sell Castrol there so play it safe and buy that Not heard of that company before, but I will look out for it. The ones I have used in the past are Ratio, Baumarkt and Praktiker. Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted November 30, 2006 Share Posted November 30, 2006 Not heard of that company before, but I will look out for it. The ones I have used in the past are Ratio, Baumarkt and Praktiker.Cheers, Paul. Keep an eye out for the Orange Beaver Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 30, 2006 Author Share Posted November 30, 2006 I will and thanks Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 30, 2006 Author Share Posted November 30, 2006 Cheers Les Quote Link to comment Share on other sites More sharing options...
freeagent Posted November 30, 2006 Share Posted November 30, 2006 i use JCB blue waterproof grease for UJ's and bearings, its realy thick and sticky, and seams to repel water realy well... engine oil... i use ASDA own brand diesel engine oil, 15/40 grade, its about £7.50 for 5 litres, i know its a bit carp, but i change it every 4,000 miles and am of the opinion that its better to use a cheaper oil and change it more regularly, than a good oil that you don't want to chuck out until its done 10,000 miles... there is a lot of rubbish spoken and printed on the subject of engine oil, most of the people who insist you use mega expensive oil usually work for oil companies... oil degrades when you use your engine, it suffers heat damage, absorbs water, gets contaminated, and the molecules suffer chain cleavage that over time robs the oil of many of its favorable properties.. even realy expensive oil degrades in just the same way... use what you like, but bin it after 5,000 miles.... Quote Link to comment Share on other sites More sharing options...
Paul64 Posted December 1, 2006 Author Share Posted December 1, 2006 i use JCB blue waterproof grease for UJ's and bearings, its realy thick and sticky, and seams to repel water realy well... engine oil... i use ASDA own brand diesel engine oil, 15/40 grade, its about £7.50 for 5 litres, i know its a bit carp, but i change it every 4,000 miles and am of the opinion that its better to use a cheaper oil and change it more regularly, than a good oil that you don't want to chuck out until its done 10,000 miles... there is a lot of rubbish spoken and printed on the subject of engine oil, most of the people who insist you use mega expensive oil usually work for oil companies... oil degrades when you use your engine, it suffers heat damage, absorbs water, gets contaminated, and the molecules suffer chain cleavage that over time robs the oil of many of its favorable properties.. even realy expensive oil degrades in just the same way... use what you like, but bin it after 5,000 miles.... Thanks, sounds like sensible advice to me. Cheers, Paul Quote Link to comment Share on other sites More sharing options...
Mark90 Posted December 1, 2006 Share Posted December 1, 2006 i use ASDA own brand diesel engine oil, 15/40 grade, its about £7.50 for 5 litres, i know its a bit carp, Cheap doesn't always equal carp, just like expensive doesn't always equal quality. What's the API spec of Asda's own oil? I know Halfords own brand stuff is good quality, better than some big expensive brand names. Quote Link to comment Share on other sites More sharing options...
