crossy Posted November 30, 2006 Share Posted November 30, 2006 Hi all, Can someone please tell me the specs of the one ton landy rims. 16 x 9 ? back spaceing ? Thanks. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted November 30, 2006 Share Posted November 30, 2006 Hi all,Can someone please tell me the specs of the one ton landy rims. 16 x 9 ? back spaceing ? Thanks. 109" 1 ton or 101" 1 tonne??? 109" 1 ton are 6.50" x 16" x 20.3mm offset, in from bolting face, i.e. the tyre centre line is 20.3mm behind the bolting face. Quote Link to comment Share on other sites More sharing options...
crossy Posted November 30, 2006 Author Share Posted November 30, 2006 Thanks Phill, Is there a difference between the 101 and the 109(1 ton) rims ? Quote Link to comment Share on other sites More sharing options...
western Posted November 30, 2006 Share Posted November 30, 2006 Yep, the 101 rims are 6 stud others are 5 stud. Quote Link to comment Share on other sites More sharing options...
V8Nick Posted January 2, 2007 Share Posted January 2, 2007 109" 1 ton are 6.50" x 16" x 20.3mm offset, in from bolting face, i.e. the tyre centre line is 20.3mm behind the bolting face. There are 2 different types. The standard ones and the extra offset ones. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted January 2, 2007 Share Posted January 2, 2007 There are 2 different types. The standard ones and the extra offset ones. Correct sort of, 109" 1 ton & 2B forward control. 1 ton, 20.3 mm offset in towards the diff, this is the same as wolf rims. 2B, 1 mm offset outwards from the diff. Both 6.5" x 16". Quote Link to comment Share on other sites More sharing options...
V8Nick Posted January 5, 2007 Share Posted January 5, 2007 Right then! I've been taking a few photos. What's the use of having One Ton wheels cluttering up your hallway, if I can't provide an example! Note that the position of the hub, and therefore it's fixing rivets is the only difference between the FC rim (grey) and the Extra Offset rim (silver). Cheers, Nick P.S. Kenny is a One Ton BTW. Quote Link to comment Share on other sites More sharing options...
