Another V8 identification
stobbie
Hi, I too have a V8 identification problem..
I have a Range Rover Classic LSE. I thought it had the standard 4.2 V8 but I found an old receipt in the pile of receipts that statet that a brand new 4.6 engine was fitted 10 years ago.
I have looked but there is no engine number on the block.
I has one small serpentine belt and a few V-belts.
I have some tappet noise and would like to replace them and the cam but have no ideas what to order. I probably should buy a timing chain as well.
Could someone point me in the right direction?
You have a dizzy, so will be an earlier cam, no idea what it would be, but not a 4.6 grind, as they don't exist.
If suspect it would be an aftermarket item anyways, so go to somewhere like v8tuner and sewer what is on offer.
Thanks. Dropping the sump is a bit too much work just for identification . But I could look in the sump with an endoscope at the next oil chance. .
So, if I understand it right, any cam for a dizzy V8 will physically fit? For fitment it is just dizzy or no dizzy?
