MuddyWinny Posted November 3, 2016 Share Posted November 3, 2016 Would anyone be able to to know the part number for core plugs for a 300tdi? The engine is from a 1994 Discovery. Specifically, it is the core plug at the back of the block (not the one in the head) that has failed and leaking coolant. Actually there are two at the back of the block, one smaller than the other and it is the smaller one, that has failed (I believe the larger one has oil behind it so is less likely to need replacing). Are all the 'coolant core plugs' the same size and hence same part number? Thanks Mark Quote Link to comment Share on other sites More sharing options...
western Posted November 3, 2016 Share Posted November 3, 2016 See items 5 & 6 in http://www.albrit.de/UNI.cfm?PAGE=748772&SPRACHE=EN click on + to read part numbers Quote Link to comment Share on other sites More sharing options...
MuddyWinny Posted November 4, 2016 Author Share Posted November 4, 2016 Western, Thanks for replying but I need the core plugs for the block. Are these the same as the ones in the cylinder head or is there another parts diagram somewhere? Thanks Mark Quote Link to comment Share on other sites More sharing options...
western Posted November 4, 2016 Share Posted November 4, 2016 on that page, click on Engine in the brown strip, it'll take you to the engine page, then click on 2500 - Diesel - Turbo - 300 Tdi that's opens the drop menu, then click on Cylinder Block which opens this page http://www.albrit.de/UNI.cfm?PAGE=748587&SPRACHE=EN block core plugs are item 3, click + to get part number there are 6 on the engine block Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 5, 2016 Share Posted November 5, 2016 I just go to local engine rebuilder and he supplies them from his huge stock of various sizes. You must have someone localish Quote Link to comment Share on other sites More sharing options...
MuddyWinny Posted November 9, 2016 Author Share Posted November 9, 2016 Thanks Western. Nice to know there are 6 on the block. Since the diagram doesn't show the core plug at the back of the block I wasn't sure whether ERC4996 was the right part or not. ejparrott - I'm aware of a couple of engineering companies but I'm not sure whether they build as well as re-bore/ skim etc. One does sell parts such as pistons etc so is worth asking. Thanks again. Mark Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 10, 2016 Share Posted November 10, 2016 Always worth asking, last got cost me about 50p each Quote Link to comment Share on other sites More sharing options...
