reb78 Posted November 13, 2016 Share Posted November 13, 2016 I;ve got a strange weep of engine oil on the 200tdi. It seems to be traveling along one of the water pump studs. Bad pic below, but its an awkward spot to photograph I've pinched the photos below from one of Les's how to threads to show the stud more clearly. Its the stud that i think Les must have removed to the far left of the photo (on mine at least, its a stud with a nut rather than a bolt: The photo below (another of Les's) shows where the stud goes through to the block - its the hole on the far left of the water pump attachment again: I wouldnt have thought this stud would go through into a part of the block that reaches an oil way? Is there another problem here? Would I get away with removing it without a strip down and applying some threadlock to the other end to seal it? Or should i just leave it until the next timing belt change? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted November 13, 2016 Share Posted November 13, 2016 It could be a leak between the block and timing chest as that bolt goes through the cover and chest into the block. I know the area between block and chest does have oil in it so I suggest you leak is there and tracking down the stud. If it was me I would pull the stud clean it put some sealant round it and put it back. Then next time you have the timing belt off replace the block to chest gasket while your at it. Mike Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 13, 2016 Author Share Posted November 13, 2016 Ah, bugger. I pulled the chest a couple of years ago and did the gaskets etc. What a pain. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted November 13, 2016 Share Posted November 13, 2016 fibre washer and a nyloc? Quote Link to comment Share on other sites More sharing options...
