Redcard Posted January 31, 2011 Share Posted January 31, 2011 Hi all Im new on here and to my 110 defender. I'm looking for some ideas for boxing out the back of the van and making a bulkhead with a perspex hatch. I will also add a few LED strip lights and hopefully put something on the roof to stop the drips. If some has any pic's it would be very helpful Thanks Red Quote Link to comment Share on other sites More sharing options...
Frax Posted January 31, 2011 Share Posted January 31, 2011 Hi and welcome. Well I did the back of my 90 with ply and then covered in carpet just so it looked better, also fitted foil covered camping mats to the roof with spray glue, this cut down on condensation and helped keep it a bit warmer. Have a look at his just for ideas http://cgi.ebay.co.uk/Vivaro-plywood-shelving-van-racking-ply-lining-/120666869902?pt=UK_CarsParts_Vehicles_CommercialVehicleParts_SM&hash=item1c184e508e As for the Perspex – it would give you a lot of reflections from your dash and also oncoming cars in the dark. Regards Frax Quote Link to comment Share on other sites More sharing options...
Redcard Posted February 1, 2011 Author Share Posted February 1, 2011 Thanks Good thinking regarding the reflection Quote Link to comment Share on other sites More sharing options...
brighouse shed Posted March 9, 2011 Share Posted March 9, 2011 dug out some piccies of my interior, one sheet of ply cut £15, 4m of cheap cord carpet from some carpet warehouse £16, one roll loft insulation from wickes £9, two aerosols of carpet glue £8 some heavy smooth rubber underlay had lying around and then a couple of hours measuring cutting and fiddling. Just be warned that glue bonds instantly you get maybe thirty seconds before it really grabs. Quote Link to comment Share on other sites More sharing options...
Steve King Posted March 9, 2011 Share Posted March 9, 2011 THESE are very easy to fit - not cheap though! Quote Link to comment Share on other sites More sharing options...
brighouse shed Posted March 9, 2011 Share Posted March 9, 2011 as you say not cheap Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 9, 2011 Share Posted March 9, 2011 Those side panels from TGE do look good. However looking at the photos on their website, it appears as if there are 2 different styles of panel yet there is no mention of this? Also, are they trying to say that NOTHING fixes the panels apart from the seatbelt bracket? Edit: Just noticed that one of the pics shows the utility panel which is a different style. Quote Link to comment Share on other sites More sharing options...
Steve King Posted March 9, 2011 Share Posted March 9, 2011 Also, are they trying to say that NOTHING fixes the panels apart from the seatbelt bracket? That is what they claim, but that leaves the other end flapping unless you have a full length headlining! They supply some flat headed screws to fix the panel to the top and waist. They also supply the correct size drill bit (however in my case the poxy thing wasn't properly hardened and it twisted and broke as soon as it touched metal! ) Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 9, 2011 Share Posted March 9, 2011 Hmmm Dont suppose you have any pics of the where the panels fixed? Quote Link to comment Share on other sites More sharing options...
Steve King Posted March 9, 2011 Share Posted March 9, 2011 Hmmm Dont suppose you have any pics of the where the panels fixed? I'll see if I can take a pic or two tonight. Quote Link to comment Share on other sites More sharing options...
brighouse shed Posted March 9, 2011 Share Posted March 9, 2011 All the sites i looked at implied that you take off seatbelt mount slide in panel and job's a good 'un. i think if you have a headlining it may work but not in mine. I cut the seat belt hole about 5mm too far forward so the panel is rammed up against the rear. then put in two self tappers on top rail and one at the bottom of central spine. That way i kept the horizontal beam (tub top?) untouched, partly cos i like the band of blue and also it was looking too complicated to sort out the levels between top rail, vertical spars and the 'tub beam' . I did run for a while with it held in place but it rattled constantly spoiling my normal near silent truck, a couple of self tappers and no problem since. Quote Link to comment Share on other sites More sharing options...
Steve King Posted March 9, 2011 Share Posted March 9, 2011 Had to work a bit late tonight and it was too dark to take any pics tonight- I'll try tomorrow morning. The TGE panels have the seat belt bracket hole pre-drilled. Once I had put the screws in the rear of the panel it was much quieter than without the panels. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted March 9, 2011 Share Posted March 9, 2011 Had to work a bit late tonight and it was too dark to take any pics tonight- I'll try tomorrow morning. The TGE panels have the seat belt bracket hole pre-drilled. Once I had put the screws in the rear of the panel it was much quieter than without the panels. Vambo how sturdy are the panels? Dave. Quote Link to comment Share on other sites More sharing options...
Steve King Posted March 9, 2011 Share Posted March 9, 2011 Vambo how sturdy are the panels? Dave. They are IMHO sturdy. Basically they are {at a guess) decent quality 3/8" ply with a fuzzy kind of fabric covering. As I said before they are expensive, but they do work in (a) quietening the drumming in the rear of my 110 hardtop and (b)cutting down the condensation - just got to sort out the roof now! Quote Link to comment Share on other sites More sharing options...
Steve King Posted March 10, 2011 Share Posted March 10, 2011 If I've done it right there should be a couple of pics attached. The one with the speaker shows one of the mounting screws at the top. Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 10, 2011 Share Posted March 10, 2011 Thanks for the pics vambo. Looks tidy. Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted March 10, 2011 Share Posted March 10, 2011 Vambo, those panels look great, exactly the kind of thing I'm after. Quote Link to comment Share on other sites More sharing options...
cornishlandrover Posted May 9, 2012 Share Posted May 9, 2012 Hi all im new to the website, thought i would just share a pic of the rear tub of my 90. Im currently insulating the sides, for warmth and sound proofing. Im useing thick fibre 1nch floor underlay. I will ply line the the sides and deck. Sides in 6mm ply and deck in 12mm ply. Anyway ive uploaded a pic of it ready to go and will add more pics as i go. Quote Link to comment Share on other sites More sharing options...
cornishlandrover Posted May 9, 2012 Share Posted May 9, 2012 Some pics of my landrover defender 90 ply lining Quote Link to comment Share on other sites More sharing options...
Boris113 Posted May 10, 2012 Share Posted May 10, 2012 Hi all Im new on here and to my 110 defender. I'm looking for some ideas for boxing out the back of the van and making a bulkhead with a perspex hatch. I will also add a few LED strip lights and hopefully put something on the roof to stop the drips. If some has any pic's it would be very helpful Thanks Red I have a mate with an ex-utilities 110. His has a wooden bulkhead built behind the seats (with prespex window) and lockers built on top of the seatboxes. I can dig out the camera and take some pictures if you are still after some? Quote Link to comment Share on other sites More sharing options...
cornishlandrover Posted May 10, 2012 Share Posted May 10, 2012 Here is my home made ply lining allmost complete. Quote Link to comment Share on other sites More sharing options...
