Prith Posted July 28, 2014 Share Posted July 28, 2014 I have a Def 110, 1991 model. I used to have a funny problem, when I switch ON the headlight in the evening/night and drive, the Ampmeter show negative readings and the Horn sounds very weak. Also Funny thing is that the temp gauge goes up. Even though the engine temp is normal. The minute I switch OFF the headlights the temp drops and the Horn now sounds OK. Thought it was my battery which was 7 years old. Hence did this: Bought a brand new 100 Amp Battery and also decided to go in for a better new Alternator. Now in the morning when I start the Landy, the Ampmeter still shows negative and once she starts it climbs to the middle. No problem with starting as there is enough of Juice. On evening drives the story is the same. Once I switch On the Headlights or Spot lights the amp meter goes to negative and more this time and again the Horn is very weak. Still the Temp gauge goes up. All this stops once I switch Off the headlights. Wondering what is happening. Checked the battery and alternator all are brand new and its charging the battery too. Any advise from the Landy Gurus will be helpful. Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted July 28, 2014 Share Posted July 28, 2014 Sounds like a bad earth, I would start there first, and not just the battery terminal, all of them, body, chassis, transfer box. Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted July 28, 2014 Share Posted July 28, 2014 Check your earth connections. Clean them, replace the earth leads if they look too far gone and see of that makes a difference. A lot of those systems you mentioned share common earth points. Many complaints about bad electrics on LRs are solved by sorting the earths. Let us know how you get on! Josh Quote Link to comment Share on other sites More sharing options...
Prith Posted July 28, 2014 Author Share Posted July 28, 2014 Thanks guys, am a novice so where are the earth points on a landy? What do I need to do when I find the earth point. Scrape the paint underneath it ? Etc Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted July 29, 2014 Share Posted July 29, 2014 Find a Haynes or LR or RAVE manual and give it a read. Invaluable learning exercise which will endow you with knowledge to get the jobs done! Earth straps from battery to engine, to chassis to gearbox I think. Also behind the instrument cluster there is one Quote Link to comment Share on other sites More sharing options...
Sharpe Posted July 29, 2014 Share Posted July 29, 2014 Should be one earth from battery to gearbox casing, engine strap (on mine from rhs of engine, looking from front, half way down to chassis bracket) and one side of fuel filter on bulkhead - under drivers window in engine bay - black wire attached). HTH. Quote Link to comment Share on other sites More sharing options...
Sharpe Posted July 29, 2014 Share Posted July 29, 2014 Disconnect neg on battery, clean all connections both sides with wire brush, bit of sanding, till nice and shiney, both connector and area connected too. Quote Link to comment Share on other sites More sharing options...
steve b Posted July 29, 2014 Share Posted July 29, 2014 The main earth problem is usually the one on the bulkhead - just to the side of the clutch pedal box under the bonnet . You'll find it easily as it should have 5 or 6 black wires with ring terminals . Run one from there to battery and check all the others , battery to gearbox and engine to chassis usually near the engine mount on the exhaust side keep us posted on your progress cheers Steveb Quote Link to comment Share on other sites More sharing options...
Prith Posted July 30, 2014 Author Share Posted July 30, 2014 Thanks a ton all of you. Should be able to do this all on the weekend. Quote Link to comment Share on other sites More sharing options...
