slihp Posted December 15, 2014 Share Posted December 15, 2014 Is there an easy way to tell if your starter is going. when i crank mine from cold its started to dose nothing (the starter dosent even energize) on the first turn then starts on the second. Quote Link to comment Share on other sites More sharing options...
Team Idris Posted December 15, 2014 Share Posted December 15, 2014 I run a bulb all the while to the top of the starter. Then you know it is getting good voltage (dim bulb/bright bulb) and if the ignition switch is working to send power. Quote Link to comment Share on other sites More sharing options...
slihp Posted December 15, 2014 Author Share Posted December 15, 2014 just went out to start it, turned on ignition, waited for glowplugs went to crank it and just went click. same thing second time , third time it starts. when it dose crank i wouldn't say it was strugling.. Quote Link to comment Share on other sites More sharing options...
AMB Posted December 15, 2014 Share Posted December 15, 2014 Sticky solenoid? Quote Link to comment Share on other sites More sharing options...
qwakers Posted December 15, 2014 Share Posted December 15, 2014 +1 on that one. Quote Link to comment Share on other sites More sharing options...
slihp Posted December 16, 2014 Author Share Posted December 16, 2014 new starter? or can be fixed? Quote Link to comment Share on other sites More sharing options...
Escape Posted December 16, 2014 Share Posted December 16, 2014 No need for a new starter, reconditioned ones aren't expensive, around €100 over here. Or you could try and recondition it yourself, could be as simple as giving it a good clean to get all the muck of. Quote Link to comment Share on other sites More sharing options...
slihp Posted December 16, 2014 Author Share Posted December 16, 2014 ok thanks chaps, thats the first step. Quote Link to comment Share on other sites More sharing options...
slihp Posted December 17, 2014 Author Share Posted December 17, 2014 my god, had a look tonight at what im face with on sat to get the starter motor out. by all accounts it can be done from ontop but it looks impossible. removing the air intake will give better access. Quote Link to comment Share on other sites More sharing options...
Escape Posted December 18, 2014 Share Posted December 18, 2014 my god, had a look tonight at what im face with on sat to get the starter motor out. by all accounts it can be done from ontop but it looks impossible. removing the air intake will give better access. It's not that hard from underneath. One bolt is a bit awkward to get to, but all very straightforward. And a Defender is high enough not to need a ramp for access, just find something soft to lie on. Filip Quote Link to comment Share on other sites More sharing options...
slihp Posted December 18, 2014 Author Share Posted December 18, 2014 mines has a 2" lift so may be easier too. Ill keep both opions open then. Cheers Quote Link to comment Share on other sites More sharing options...
slihp Posted December 20, 2014 Author Share Posted December 20, 2014 Well get it off, the hard bolt wasn't that bad bit of a pain that's all. the other two easier ones were the problem, torqued right on real difficulty cracking them in limited space. Agreed from underneath is the best. I cant see how you can get to that bolt from above Quote Link to comment Share on other sites More sharing options...
