dave1607 Posted May 4, 2015 Share Posted May 4, 2015 I've got a 2003 TD5 90 and the gear change between 1st and 2nd, and 2nd and 3rd isn't great, I've changed the oil and it was slightly better but still not as good as my old 300tdi 90. If I change slowly, or at low engine revs, I can get a smooth change. I had put this down to wear or maybe this is just the way this gearbox is, but then I realised that if I keep a bit of pressure on the gear stick, holding it over to the left, while I change between 1st and 2nd the change is absolutely fine at any speed. Does this make sense to anyone? Thanks Dave Quote Link to comment Share on other sites More sharing options...
Boydie Posted May 4, 2015 Share Posted May 4, 2015 Check that the "nylon" ball joint isn't worn. Quote Link to comment Share on other sites More sharing options...
dave1607 Posted May 6, 2015 Author Share Posted May 6, 2015 Check that the "nylon" ball joint isn't worn. I'll have a look at that, the gear change isn't sloppy, infact it is quite positive, but it's worth a look. I may be imagining that it's better if I hold the stick over to the left, just clutching a straws in hope that it wont mean that I need to change the gearbox. I might give some of this fancy synthetic oil a go, at the moment it has fresh MTF94 in it from Smith and Allen so it might make no difference, and the synthetic stuff it is quite pricey, but not as pricey as a recon box. Has anyone tried the Difflock evolution 1 or the Redline stuff and was it any good? I'm leaning towards the Redline MTL after a bit of googling, but there seem to be a few different ones, which one should I be looking for? Thanks Dave Quote Link to comment Share on other sites More sharing options...
dave1607 Posted May 12, 2015 Author Share Posted May 12, 2015 Just a quick update. The gear change being better when I hold the stick over to the left was in my imagination, so on Friday last week I ordered 3 litres of Redline MTL to give that a try. Now .......... I've been driving it every day since I put fresh MTF in the gearbox to give it a chance to get around everywhare expecting that the gear change would gradually get better, but it hadn't, which is why I ordered the Redline oil. But when driving home on Friday after ordering the Redline stuff, the gear change started to get a bit better to the point where this morning there was no crunch what so ever between 1st and 2nd. So it turns out that to fix the problem all I had to do was order £55 worth of oil and the second I hit "Buy" the problem fixed itself. Dave Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted May 12, 2015 Share Posted May 12, 2015 I find that the quality of the gear shift feel changes a lot with the weather, and not just temperature. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 12, 2015 Share Posted May 12, 2015 Weird .... Quote Link to comment Share on other sites More sharing options...
cackshifter Posted May 14, 2015 Share Posted May 14, 2015 Classic Psod's law Quote Link to comment Share on other sites More sharing options...
