montyjn Posted February 20, 2017 Share Posted February 20, 2017 So, I know this topic has been written about slightly to death, but I am a little unsure if the various solutions apply for the earlier 5mm glass. I currently have the annoying 'chatter' from rattling glass.. I know that the wollies trim option does not work (from experience) with this wider glass. Has anyone else found a solution (keeping the windows sliding - I appreciate that I could just replace the whole window with a solid piece of glass). For example, I think this option would not work: http://www.mudstuff.co.uk/garrison-sw-rear-window-kit.html. Any help greatly appreciated! Quote Link to comment Share on other sites More sharing options...
neil110 Posted February 20, 2017 Share Posted February 20, 2017 I have used the Garrison outfitters replacement window "felt" on my early 110 with 5mm sliding windows and it works very well. The early kits were an absolute pig to fit but the later versions are much easier. They have been in position now for about 5 years and still no rattles Quote Link to comment Share on other sites More sharing options...
montyjn Posted February 21, 2017 Author Share Posted February 21, 2017 Thanks Neil. I was a little thrown by the fitting instructions which seemed to say that it only worked on the 4mm glass. Will give it a go! Quote Link to comment Share on other sites More sharing options...
reb78 Posted February 21, 2017 Share Posted February 21, 2017 I want to replace mine with solid glass on both sides, but need to remove the frames to get the measurements for the glass and work out what rubber fittings I need. 1 Quote Link to comment Share on other sites More sharing options...
kevh Posted February 21, 2017 Share Posted February 21, 2017 I had to remove the glass out of frames, yes pain in the rear as whole frame to be removed( mine were out anyway as i was putting them in the side of an ambulance) I found it was the felt strip that the glass slides on had deteriated over time allowing annoying rattle and water ingress. The replacement felt strips came individually and were fairly easy to fit, re-assembled frame etc, Glass now slides smoothly with no rattles or leakage. Bit of work, but worth it Kev Quote Link to comment Share on other sites More sharing options...
joe1 Posted February 21, 2017 Share Posted February 21, 2017 Wow, just checked that Garrison price - @120 I nearly dropped me bacon sandwich! I think I might be investigating inner tube cut to size for my old clunker..... Quote Link to comment Share on other sites More sharing options...
montyjn Posted February 21, 2017 Author Share Posted February 21, 2017 Woolies trim sell a much cheaper solution for 4mm glass.. Quote Link to comment Share on other sites More sharing options...
kevh Posted February 21, 2017 Share Posted February 21, 2017 £19 for OEM felt, cant remember seeing a woolies for a while though? Quote Link to comment Share on other sites More sharing options...
