what grease is this?
Yolandi
By it's a long time since I saw that type of grease. I may have a baccy tin with some in. The bus company I worked for had to keep the steering drop earms polished for the traffic commisioner. After polish that type of grease was used to cover then. As Mike says it was a water repelant grease.
Hang on, isn't all grease water repelant.
Make sure the adapter coupling is nice and tight. Normally you can rotate the collar so that the four collets are slack or tight around the nipple when grease is applied. The pressure from the pumping action should tight the collets onto the nipple. I'm assuming your grease nipple is blocked up.
had similar problems with a later (post '94) 110 where the yokes have to be in a particular position in order for the grease gun to fully engage on the nipple. I got round it in the end by buying a nipple that is about 25mm long. I only fit it when I am greasing the props, the rest of the time I put a grub screw in the UJ
That's what I've been doing since I bought my Defender
