chadler Posted March 17, 2009 Share Posted March 17, 2009 Short and sweet question... Does an r380 have a breather on it? If so then how come i can't find it anywhere despite having the floor and centre tunnel out of my 90? I've got a raised breather kit that i'm fitting and it's driving me mad not knowing if i've missed one. Quote Link to comment Share on other sites More sharing options...
chadler Posted March 17, 2009 Author Share Posted March 17, 2009 if it makes any difference then it's a short-bellhousing version fitted to a 200tdi, not the more common long version. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 17, 2009 Share Posted March 17, 2009 It's near the top, near the back on the driver's side (assuming RHD!) not a million miles from the difflock linkage gubbins. Quote Link to comment Share on other sites More sharing options...
chadler Posted March 17, 2009 Author Share Posted March 17, 2009 Ok this just gets stranger and stranger. It's a brand new gearbox so there is no oily muddy sludge to hide things. I have, after googling for any picture of an R380 I can find, located a threaded hole on the RHS of the gearbox, on the raised flange where the silver (rear) part of the gearbox meets the black (forward) part. First impressions of the hole though are that there is no way an elbow fitting will fit under and clear the difflock linkage. And as suspected, it won't. I'll try to take a photo nopw to show what I mean. I'm sure this is an idiosyncracy of the short bellhousing gearbox. I don't even think that a normal banjo fitting would be low enough profile to fit, but that's the next plan.... here is a picture of an R380 that I just found that shows the proper breather location (Not My Gearbox), the breather is where the bit of black pipe joins the sticky-out bit at a 45 degree angle. Quote Link to comment Share on other sites More sharing options...
ashtrans Posted March 17, 2009 Share Posted March 17, 2009 all 4 wheel drive 380's have the breather here, same as photo, are you sure you have a 380 ? whats the serial number ? Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2009 Share Posted March 17, 2009 I have a stumpy bel housing R380 & it's breather is on the right upper side to the rear of the difflock linkage, Item 51 on this page from the Defender workshop manual. Quote Link to comment Share on other sites More sharing options...
chadler Posted March 17, 2009 Author Share Posted March 17, 2009 all 4 wheel drive 380's have the breather here, same as photo,are you sure you have a 380 ? whats the serial number ? Very sure, you sold it to me Sir! The reason I was so stumped was due to the fact that the hole was completely obscured by the ratio-linkage and just looked like a blind hole in the casting - it had no existing breather fitting on it. Only by poking a cable tie into it did I discover that it went all the way inside the 'box. The shift housing is further forward than on a long R380 I think and therefore completely obscures the breather fixing. I managed to get a banjo fitting to fit under the linkage, and I'm glad I didn't give up as I would have been leaving a hole straight through into the gearbox internals. A few photos to round up the thread and make it useful for future reference... elbow fitting obstructed by linkage Linkage removed, showing elbow location banjo fitting under linkage Transfer box breather, photo taken from under driver's seat transfer box breather location Quote Link to comment Share on other sites More sharing options...
chadler Posted March 17, 2009 Author Share Posted March 17, 2009 I have a stumpy bel housing R380 & it's breather is on the right upper side to the rear of the difflock linkage, Item 51 on this page from the Defender workshop manual. Ralph, that's even odder, because as you can see from my annotation of your diagram, that's not where my breather is! Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2009 Share Posted March 17, 2009 cos the info I posted is for the more common 300Tdi R380, but mine is in the same place as yours. but I 'd have thought the casings are common parts. Quote Link to comment Share on other sites More sharing options...
ashtrans Posted March 17, 2009 Share Posted March 17, 2009 the casings are all the same, the diagram is wrong, thats a LT77 breather Quote Link to comment Share on other sites More sharing options...
chadler Posted March 17, 2009 Author Share Posted March 17, 2009 One for the tech archive? Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2009 Share Posted March 17, 2009 the casings are all the same,the diagram is wrong, thats a LT77 breather We can lay the error at LR then for using a LT77 diagram in the R380 gearbox section of the RAVE CD Defender workshop manual. Quote Link to comment Share on other sites More sharing options...
