Stellaghost Posted November 21, 2023 Share Posted November 21, 2023 Can you post a picture of the spring, there might be something similar that could do the job Regards Stephen Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 21, 2023 Share Posted November 21, 2023 3 hours ago, joiner55 said: Hi again CwazyWabbit sorry for delay in replying and thank you for your original reply, unfortunately the springs broken in the middle. I did think about having a go at welding it but it seems the springs the week point as it is so welding it might only work for a short term. Also thanks daveturnbull but I've already been intouch with Vice Works and unfortunately they couldn't help. I have however been trawling tinternet and found a Record vice QR spring that I think I might be able to make work. I don't think a weld on a spring would last long tbh. This one on eBay for a Record (probably the one you have already found) looks like it would work. https://www.ebay.co.uk/itm/174838116657 It has the following dimensions so you should be able to get an idea of the chances of it fitting before purchasing. (The spring ends as far as I can see look right too) Spring measures approx: Overall length: 83.5 mm External Spring diameter: 19 mm Internal Spring diameter: 14.2 mm Wire diameter: 2.2 mm Quote Link to comment Share on other sites More sharing options...
joiner55 Posted November 21, 2023 Share Posted November 21, 2023 Yes that's the spring CwazyWabbit, it's not a perfect match but I think I can work with it. The internal diameter is about the same, it's not quite as long as the original but I'll make a spacer if needed. Stellaghost there's a couple of pictures in the ebay link in CwazyWabbit's last reply. 1 Quote Link to comment Share on other sites More sharing options...
joiner55 Posted November 27, 2023 Share Posted November 27, 2023 The Record spring worked, just needed a little bit of fettling 3 Quote Link to comment Share on other sites More sharing options...
