pfwilko Posted November 5, 2017 Share Posted November 5, 2017 Hi to all Is there anyone who can tell me how to get the rear headrests off a D4. they are bog standard. The hand book says hold the button in that allows it to be adjusted and continue pulling up.This is the way I have always removed them on other cars. I have tried this and they are solid. There is no way they will come up any further let alone come out. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted November 5, 2017 Share Posted November 5, 2017 IMO more brute power is needed, ask somebody to hold the button and pull with both hands Quote Link to comment Share on other sites More sharing options...
teabag Posted November 6, 2017 Share Posted November 6, 2017 19 hours ago, pfwilko said: Hi to all Is there anyone who can tell me how to get the rear headrests off a D4. they are bog standard. The hand book says hold the button in that allows it to be adjusted and continue pulling up.This is the way I have always removed them on other cars. I have tried this and they are solid. There is no way they will come up any further let alone come out. Oh no it doesn't, this it the exact wording quoted from my copy "Raise the head restraint to its uppermost position and press the locking collar." If that doesn't work in releasing then you have a problem. Quote Link to comment Share on other sites More sharing options...
changread Posted November 10, 2017 Share Posted November 10, 2017 Press the other concealed button. Quote Link to comment Share on other sites More sharing options...
Disco iv Posted November 7, 2020 Share Posted November 7, 2020 You need a small flat head screwdriver. There is a small clip on the arm of the headrest opposite to the arm with the conventional release clip. Depress small clip and raise the headrest out of the seat. Quote Link to comment Share on other sites More sharing options...
Bohica Posted August 3, 2021 Share Posted August 3, 2021 Finally was able to remove my very stubborn 2nd row headrests... 1. Knees on seat bottom facing headrest 2. On left stem, pull out locking clip and raise headrest to full height 3. On right stem, press in on concealed locking clip (w/screwdriver/coin, etc) and pull right side up to unlocked position. 4. While use right hand to maintain upward pressure on right side...push in on left side locking clip to fully release headrest. Quote Link to comment Share on other sites More sharing options...
Bonbon Posted January 25, 2022 Share Posted January 25, 2022 Okay so I am struggling removing the headrest in my 2021 Discovery. I need to remove the middle seat headrest to fit a car seat. How can I find the concealed locking clip? Quote Link to comment Share on other sites More sharing options...
PhilG Posted September 28, 2022 Share Posted September 28, 2022 On 1/25/2022 at 4:47 AM, Bonbon said: Okay so I am struggling removing the headrest in my 2021 Discovery. I need to remove the middle seat headrest to fit a car seat. How can I find the concealed locking clip? So I just removed the centre headrest from my 2018 Disco. It is likely the same for the new facelift model. From the back seat, fold the headrest up. 1 pull the retaining clip in the right stem out completely. Remove it. 2 push a flat head screwdriver under the left stem cowl trim from the outside left - it pushes a hidden clip inward, I used a plastic trim tool so I didn’t rip the leather. 3 pull the headrest up and out Quote Link to comment Share on other sites More sharing options...
Yves Rubin Posted January 1 Share Posted January 1 I have the same problem, but with a 2024 Defender 110. It looks like they changed the locking system entirely, since there is no left (when looking at the head rest from the front of the car) button at all. Nothing! However, the following YouTube movie: shows what may be my situation, but only mentions briefly that to dislodge the pin, you need to give it a sharp strong pull to dislodge the pin or a whack with a mullet on the head rest. Has anyone done this? Quote Link to comment Share on other sites More sharing options...
