daveturnbull Posted November 12, 2017 Share Posted November 12, 2017 I'm looking for the right part number for a Defender 110 rear axle stub axle inner oil seal. It's 2002 with the Rover type axle. My usual parts sites have a few different ones and seem quite vague. Quote Link to comment Share on other sites More sharing options...
western Posted November 12, 2017 Share Posted November 12, 2017 2002 rear hub seal should be FTC4785 same for 2007 onwards too. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 12, 2017 Share Posted November 12, 2017 RTC3511 is a better designed seal and always preferred to the newer style FTC4785. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted November 13, 2017 Author Share Posted November 13, 2017 Thank you both. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 13, 2017 Share Posted November 13, 2017 Those numbers are hub seals, you’re asking about the stub axle internal seal though? Think you want FTC5268, item 3 below. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted November 13, 2017 Author Share Posted November 13, 2017 I think you might be right there James. It is the little one that goes inside the stub axle to stop the EP90 creeping into the wheel bearings that I need. Linky It certainly seems to be about the right size, where as FTC4785 looks a lot bigger. Quote Link to comment Share on other sites More sharing options...
western Posted November 13, 2017 Share Posted November 13, 2017 OOPS, Should have read it slower, its what James says, other is for the hub bearings, there's no problem leaving the stub seal out, better for hub bearings to have a oil bath, mine have been fine Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 13, 2017 Share Posted November 13, 2017 Keep in mind, the picture above is not quite correct. There is a needle bearing behind the seal (FTC861). It needs to be removed to get the seal changed and is not simple to remove without damage. If you really feel the need to change that seal, get a set of the bearings at the same time. Best to read the workshop manual and get yourself a copy of the parts catalog. As Western states, oil in the bearings is a good idea. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted November 13, 2017 Author Share Posted November 13, 2017 56 minutes ago, Red90 said: There is a needle bearing behind the seal (FTC861). Not on the rear axle there isn't. Quote Link to comment Share on other sites More sharing options...
