soutie Posted April 3, 2018 Share Posted April 3, 2018 In rebuilding my 1989 110 I have to replace the gasket MUC7506 which seems to have superseded gasket ANR6333. As these gaskets are in the range of £10 to £20 could I use a Gasket paper to make them up to save myself some money? I was thinking of using something like this. High temperature (250°c) gasket paper sheet - Phoenix PG-G CNAF graphited. It comes in various thicknesses - from 0.4mm to 3mm - which thickness should one use? Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2018 Share Posted April 3, 2018 I used a sealant on the bulkhead face & greased the base face of the clutch pedal unit last time mine was removed for a tidy up. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted April 4, 2018 Share Posted April 4, 2018 You are sealing against water ingress and if it leaks it's direct onto your feet. So as Western says, I'd use a sealant. Quote Link to comment Share on other sites More sharing options...
soutie Posted April 5, 2018 Author Share Posted April 5, 2018 Thanks. Appreciate the replies. Quote Link to comment Share on other sites More sharing options...
