samcrook Posted December 16, 2006 Share Posted December 16, 2006 Hi Guys, My first post, but I've been lurking for a while I've just replaced the rear drivers side wheel bearings and brake shoes on my 200tdi 90 as the oil seal had gone. Now all was fine untill i put the drum back on which binds, this is before doing any hub nuts up. Ive checked the shoes are seated ok and the adjuster is backed off, but still no luck. Any advice ? Cheers, Sam Quote Link to comment Share on other sites More sharing options...
western Posted December 17, 2006 Share Posted December 17, 2006 the new brake shoe friction material will have to bed in, I get the same on my '89 110's rear drum brakes, after a few miles the brake bed in & then a quick readjust will give good braking. Quote Link to comment Share on other sites More sharing options...
steve_a Posted December 17, 2006 Share Posted December 17, 2006 check the shape of the drum shoes, i had some brit part ones which were complete cack and I had to grind the correct shape onto them so that they didn't bind. Not something you would normally think to check at all. If both sides though, suggest you need to look at making sure the adjusters are fully backed off. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 18, 2006 Share Posted December 18, 2006 What make are the brake shoes? Some are really poor quality/ different curve to the drum. I've had to dress brake shoes with a file before now to get a drum on. Les. Quote Link to comment Share on other sites More sharing options...
Diff Posted December 18, 2006 Share Posted December 18, 2006 Hi Guys,My first post, but I've been lurking for a while I've just replaced the rear drivers side wheel bearings and brake shoes on my 200tdi 90 as the oil seal had gone. Now all was fine untill i put the drum back on which binds, this is before doing any hub nuts up. Ive checked the shoes are seated ok and the adjuster is backed off, but still no luck. Any advice ? Cheers, Sam You said 'the adjuster is backed off' - implying that you have only backed off one adjuster. I have a 110 which has two adjusters - one for each shoe. Does the 90 not have 2 adjusters too? Hope you get it sorted, Regards, Diff Quote Link to comment Share on other sites More sharing options...
samcrook Posted December 18, 2006 Author Share Posted December 18, 2006 Just the one adjuster on 90s. Will check the shoes when i next get a chance, im sure they're britpart or simalar, could well be that. Cheers, Sam Quote Link to comment Share on other sites More sharing options...
