doppy Posted December 29, 2018 Share Posted December 29, 2018 Will 90 Axles fit onto a 110 the 110 as a non Salisbury axle fitted same year vehicles TD5 Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted December 29, 2018 Share Posted December 29, 2018 Fronts, yes Rears, yes.................. ............but there will be lots of posts arriving after mine about how it's not technically rated for the weight of a 110. The rear 90 axle is not the same as the rear 110 Td5/Puma axle Quote Link to comment Share on other sites More sharing options...
doppy Posted December 29, 2018 Author Share Posted December 29, 2018 2 hours ago, dailysleaze said: Fronts, yes Rears, yes.................. ............but there will be lots of posts arriving after mine about how it's not technically rated for the weight of a 110. The rear 90 axle is not the same as the rear 110 Td5/Puma axle Thank you . Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 31, 2018 Share Posted December 31, 2018 I think the brakes will need swapping across too, at least at the rear. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 31, 2018 Share Posted December 31, 2018 Why the want/need to swap them? Especially as you’ve already got the ‘best’ 110 rear axle. Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 1, 2019 Share Posted January 1, 2019 17 hours ago, landroversforever said: Why the want/need to swap them? Especially as you’ve already got the ‘best’ 110 rear axle. That's a subjective view. The P38 diff type axle has better ground clearance and is much cheaper to modify with different ratios and the Aschroft ATB (cheaper than competitors), but it's far more prone to failures than the Salisbury, especially the pinion bearings. Still, no way would I replace it with a long nose Rover axle. Quote Link to comment Share on other sites More sharing options...
