roamingyak Posted December 30, 2018 Share Posted December 30, 2018 I'm after a new Kenitic recovery rope - anything to be aware of when buying - major differences between brands etc? Quote Link to comment Share on other sites More sharing options...
Arjan Posted December 30, 2018 Share Posted December 30, 2018 Go for a branded quality one if you really want one. I stay away from them as I've seen a few very nasty accidents with them when the attachment points are not as good as they were beleived to be.. IF you use them, use a safety bridlle to keep things from flying too far... Quote Link to comment Share on other sites More sharing options...
roamingyak Posted December 30, 2018 Author Share Posted December 30, 2018 I've never had the need for one previously, normally always been able to pull directly out using a normal tow rope, but always keen to try new exciting things 😉 What are the brands to look for? Quote Link to comment Share on other sites More sharing options...
garrycol Posted December 31, 2018 Share Posted December 31, 2018 Do not get one that has a higher load rating than you need - when used at lower load rating than designed they so not stretch much and provide high shock loads. Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted December 31, 2018 Share Posted December 31, 2018 You might want to have a look at this link http://www.pirate4x4.com/tech/billavista/Recovery/ It will give some ideas of the forces involved in recovery. I prefer winch recovery where possible as you can control the forces applied. KERR puts a lot of force in to the operation, and if a recovery point fails can be lethal. Â Just my 2P worth. Quote Link to comment Share on other sites More sharing options...
