Bigant Posted March 12, 2019 Share Posted March 12, 2019 Hi Over the weekend the indicators stopped working on my 01 plated Discovery 2, the indicator indicators on the dash still work as they should but I have nothing working on each corner?7 I have also have a regular fault with the central locking which bizarrely seems to be related to the weather, in dry spells the internal switch works fine but in wet weather it doesn't work. Many thanks in advance Bigant Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted March 12, 2019 Share Posted March 12, 2019 If you have sunroof's they are probably leaking down into the passenger compartment fusebox or the BCU or both. Water ingress is a bad thing which is all too common in many vehicles,not just Landrovers... Have a look around the footwells and above,normally its quite obvious,corroded parts and damp carpets are the norm... Quote Link to comment Share on other sites More sharing options...
Bigant Posted March 16, 2019 Author Share Posted March 16, 2019 Thanks for that can you explain what the BCU is? I am thinking issues with a relay re the indicators are these just pull out out replace items? Thanks again Quote Link to comment Share on other sites More sharing options...
sierrafery Posted March 16, 2019 Share Posted March 16, 2019 BCU = body control unit, a very complex electronic unit behind the glovebox which is responsible for various functions including central locking and indicators ... though the interior fusebox(IDM) is suspect as well cos it's very common to be affected by water or moisture, i doubt it's a relay cos there is one for each side... you should find a known good one on ebay from a non-facelift D2 and rule it out cos it's almost plug and play, all you have to do is to disconnect the battery first then after the swap and battery reconnection turn ignition on II and let it there 5 minutes to syncronise itself with the BCU, if you are unlucky enough to be the BCU the problem becomes more complicated cos it needs complex programming with dedicated tester... here's one https://www.ebay.co.uk/itm/Land-Rover-Discovery-2-TD5-V8-Interior-Fusebox-YQE000250/254150541492?fits=Car+Make%3ALand+Rover|Model%3ADiscovery&epid=652655038&hash=item3b2c8d80b4:g:K1EAAOSwkhxcfXXk Quote Link to comment Share on other sites More sharing options...
Bigant Posted March 23, 2019 Author Share Posted March 23, 2019 many thanks for all the info, looks like its not going to be a simple fix after all Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 30, 2019 Share Posted March 30, 2019 Do the hazards work? Also check fuse 14. (under bonnet fuse box) Quote Link to comment Share on other sites More sharing options...
DiscoDara Posted April 30, 2021 Share Posted April 30, 2021 Hi everyone, I was just wondering if you could help, I have a similar problem, I’ve just bought my second disco td5 2002, on the way home, I noticed there were no indicators, neither on the dash or at the corners, at the time I had the headlights on, when I got home I was having a look and noticed when I do not have the headlights on the indicators lights flash on the dash but still not indicators, this is the same for the hazard light. when I bought the car, the previous owner explained that the immobiliser was turned off using nanocom. I have tried replacing the relays and hazard switch but to no luck, I have also inspected f14 but there is no corrosion. Ps, it’s also a non sunroof model. thank you Quote Link to comment Share on other sites More sharing options...
