ATF and "cold climate oil stc50519"
so far , reservoir, pipe's and pump are empty , so beter flush the system to get the last bit out off the steering box.
wich is the better choice to fill the system with , ATF or the "newer" steering fluid ?
it's a 300tdi pump with probeble a TD steering box.
