GW8IZR Posted April 11, 2019 Share Posted April 11, 2019 Standing in the auction crowd and this elderly FL2 comes through i stuck my my hand up and it’s mine, drove it home today - it definitely needs a driveshaft and probably a steering pump... apart from that that it goes well, well the 90 is so reliable now I needed a project 😀 shaft will be here tomorrow morning and assuming it no longer feels like driving a massage chair I’ll look at the pump. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 12, 2019 Share Posted April 12, 2019 If you mean the shaft to the rear.... it probably needs a new IRD. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 12, 2019 Share Posted April 12, 2019 8 minutes ago, landroversforever said: If you mean the shaft to the rear.... it probably needs a new IRD. Wrong vehicle - Fl1 have the dodgy viscous that seizes up, FL2 use a Haldex clutch on the rear diff, so I don't think they suffer the same set of issues as the FL1. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 12, 2019 Share Posted April 12, 2019 That will teach me to read things properly Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted April 12, 2019 Author Share Posted April 12, 2019 aha! but this one has its own issues 🙂 the shaft will not come out of the hub, eventually gave in and took the whole lot off and put it in the press - it just bent the hub knuckle casting! so a new casting required, never seen one so stuck. No sign of heat damage but it will not shift. Anyway its all stripped and new bits will be here next week 🙂 Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted April 13, 2019 Author Share Posted April 13, 2019 seems to be a bit of conflicting information out on the 'tinterweb , workshop manual download suggests the drive bolt on the front shaft should be 45Nm + 80 degrees, is there any update or other information contradicting this info? Quote Link to comment Share on other sites More sharing options...
