bushwhacker Posted April 18, 2019 Share Posted April 18, 2019 Just seeking advice on whether to keep a gear box that is popping out of reverse for spares or to refubish. I had driven the LR it came out of on many occasions and this was its only fault. The transfer box came out of a 300tdi 90 I had bought and had seized striping teeth of a couple of gears. Don't know why it seized. I am thinking there would be specialist tools and pullers to do the strip down which I don't have. Regards Mark. Quote Link to comment Share on other sites More sharing options...
lo-fi Posted April 18, 2019 Share Posted April 18, 2019 Nothing special needed to strip an LT230, just normal spanners stuff. You can certainly easily strip to assess whether there's much worth keeping. Given that they're cheap and plentiful, it's probably not worth rebuilding unless you've got spares on the shelf. The 77 does require a couple of special tools iirc, but have thumb through the manual 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 18, 2019 Share Posted April 18, 2019 Gearbox if you want to refurbish I’d send it away to be done and keep it as a spare but a transfer box is easily done at home , I’ve done 2 now . The toolbox videos on YouTube https://m.youtube.com/watch?v=vi5kHtvY-u8 are great they do a step by step guide that’s not the 1st one but will put you on the rite track , only special tools are a dial gauge ( cheap off eBay) and the big nut tool which they show you how to make one out of an old socket , so well worth doing hope this helps . Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 18, 2019 Share Posted April 18, 2019 LT230 are incredibly simple, even I've done a couple, no special tools needed. However, as they're so plentiful and robust it's hardly worth the effort unless you really want to build a properly refurbished one. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted April 18, 2019 Author Share Posted April 18, 2019 Thanks, something to ponder over. Quote Link to comment Share on other sites More sharing options...
