dave88sw Posted May 20, 2019 Share Posted May 20, 2019 Hoping someone can help put my mind at ease. I've just bought a set of piston rings for an engine i'm rebuilding. They're a good brand, ordered from my local engine remanufacturer who uses the brand for all of his rebuilds. When comparing them to the old rings, the top ring is a fair bit narrower (when viewed from the top, they're the same thickness where they fit in the groove). Should this matter? I imagine it should be fine as it's plenty wide enough to engage in the groove. The ring gap is within spec in all cylinders. Picture: Top ring is original, lower one is the new ring. Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 21, 2019 Share Posted May 21, 2019 You can only measure the gap objectively with the ring in the bore. As the outer circumference wears (as appears to be the case with the old ring), the gap will grow. Quote Link to comment Share on other sites More sharing options...
steve b Posted May 21, 2019 Share Posted May 21, 2019 They will be fine , the critical things are end gap within spec and clearance in the groove in spec too . the inside diameter is not critical at all . Fit them with the gaps at 120 degrees to the previous one , happy building cheers Steve b Quote Link to comment Share on other sites More sharing options...
dave88sw Posted May 22, 2019 Author Share Posted May 22, 2019 Thanks for the replies. I have measured the gap in the cylinder and they're fine, i was just surprised the new ring was narrower than the old one. You've put my mind at ease though, I've got to glaze bust the cylinder but hopefully i'll start fitting it up at the weekend. Thanks Dave Quote Link to comment Share on other sites More sharing options...
