ThreePointFive Posted November 7, 2019 Share Posted November 7, 2019 Not sure what these are called, but I need the part numbers for the fixings that hold these things on. Google shows nothing but there should be a plate on the wheel arch end that I need to order two of and the ones securing at the B pillar. For the avoidance of doubt, they're the silver bits flapping in the wind in this photo either side of the bulkhead bar... Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 8, 2019 Share Posted November 8, 2019 I would just make up some nuts and bolts with a suitably i insulated backing plate, common place for galvanic corrosion to set in. For early trucks the fuel filler box is awefully close to the area making getting the standard land rover fixing plate in and out a bit of a pain. Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2019 Share Posted November 8, 2019 looks like these parts on page 858 in 90 parts book. http://www.retroanaconda.com/landrover/parts_books/90/9_body_chassis_p794-923.pdf Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted November 9, 2019 Author Share Posted November 9, 2019 (edited) Thanks both, I think I will just make my own drilled plate and normal nuts and bolts, can't see any advantage in buying new. Edited November 9, 2019 by ThreePointFive 2 Quote Link to comment Share on other sites More sharing options...
