lol Posted November 13, 2019 Share Posted November 13, 2019 Hopeing someone can throw some light, ive become the owner of a non running p38 for reasonable money,it appears that the engine ecu and bcem aren’t communicating the immobiliser code to each other(engine man light doesn’t illuminate and won’t crank over) apart from a syncmate how can I get them to match? I’m a little reluctant to spend too much on the car at this stage as it’s an “unknown” as such Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted November 13, 2019 Share Posted November 13, 2019 My understanding is that it needs hooked up to a computer to reset the sync Quote Link to comment Share on other sites More sharing options...
lol Posted November 14, 2019 Author Share Posted November 14, 2019 I believe that is looking the only way too! have found this wondered if any one had tried the gems app and if it works? https://play.google.com/store/apps/details?id=com.flemcodesign.gems.gemsutility&hl=en_GB Quote Link to comment Share on other sites More sharing options...
Escape Posted November 14, 2019 Share Posted November 14, 2019 Are you sure the problem is between BECM en GEMS? If it has been standing for some time, I'd start with the EKA code. But then you'd get 'engine disabled' on the message center. Nobody with a Rovacom or similar nearby? I'd gladly help, but a bit far away... Filip Quote Link to comment Share on other sites More sharing options...
lol Posted November 14, 2019 Author Share Posted November 14, 2019 I’m fairly sure that’s where the issue is but certainly no expert on these,has been stood up for over a year with a flat battery I have entered the EKA code which cleared the engine disabled fault message on the display, ill have a ask around locally for some with Rovacom to hopefully resolve the issue Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted November 15, 2019 Share Posted November 15, 2019 The other thing to try is to disconnect both leads to the battery and hold them together for 30 seconds. That certainly clears the faults and worth a try. Quote Link to comment Share on other sites More sharing options...
lol Posted November 15, 2019 Author Share Posted November 15, 2019 Thanks for the advise chaps did just need a security relearn with Rovacom and we’re running thanks for the help 1 Quote Link to comment Share on other sites More sharing options...
