L19MUD Posted December 26, 2019 Share Posted December 26, 2019 I am after a decent 3/8 impact socket set to go with my new Makita 3/8 impact wrench. I want 6 sided short and deep sockets plus some extension bars. Ideally I want all of this in one blow moulded case so it's easy to move about. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted December 26, 2019 Share Posted December 26, 2019 I got fed up of not having the right sockets and bought pretty much the cheapest 10mm-32mm deep socket set in 1/2" drive from eBay (cost £25.99) and it's been pretty good so far (driven from my 1400 ft-lb Milwaukee High-Torque 1/2"). The only complaint I have over it was the 27mm (ironically the only socket I needed urgently for the crank bolt) had a bit of play in the drive and the Milwaukee chewed up the drive. I ended up popping down to Halfords as I needed a replacement then. The metal is obviously softer than the Milwaukee 1/2" drive but as long as there's minimal play they've been fine. For the amount of use they get I'd rather spend £26 on an entire set than £26 on each... Mind you I'm not looking after them particularly and they've survived pretty well undoing everything on the Land Rover and the tractor. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted December 26, 2019 Author Share Posted December 26, 2019 This is the best impact set I have found in 3/8 but was hoping for cheaper lol! https://www.amazon.co.uk/dp/B01N9YX0M1/ref=cm_sw_r_cp_awdb_t1_SPkbEbJ99CFX3 I have a really good Bluepoint general service 3/8 set but I don't want to abuse it with the impact gun Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 26, 2019 Share Posted December 26, 2019 I have had a 1/2 Sealey set for 20 odd years...…….. Metal case mind. I have lost a couple along the way, but none have broken, and they get used as formers, levering pivots and press tools as well. 1 Quote Link to comment Share on other sites More sharing options...
