Paddocks Posted January 6, 2020 Share Posted January 6, 2020 (edited) I have an 07 Puma 90 SW. One of the rear glass-mounted electrical spade connectors for the high-level brake light has detached from the glass. Can anyone suggest best way to re-attach please? Edited January 6, 2020 by Paddocks Title clarified Quote Link to comment Share on other sites More sharing options...
Landy7 Posted January 6, 2020 Share Posted January 6, 2020 (edited) I just ran a new wire under the seal, works like a charm and less likely to break Like this: https://www.lrukforums.com/threads/mot-defender-high-level-3rd-brake-light.135488/ Edited January 6, 2020 by Koen110 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 6, 2020 Share Posted January 6, 2020 There used to be an epoxy with metal fillings in it for this sort of thing. Not sure how effective it will be though. Mike Quote Link to comment Share on other sites More sharing options...
western Posted January 6, 2020 Share Posted January 6, 2020 Would Chemical metal or something like this work https://www.amazon.co.uk/Cargo-QuikSteel-Steel-Reinforced-Repair/dp/B00Q6XBEXM/ref=asc_df_B00Q6XBEXM/?tag=googshopuk-21&linkCode=df0&hvadid=231908893094&hvpos=1o6&hvnetw=g&hvrand=12656113277449248654&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1006597&hvtargid=pla-615624082778&psc=1 Quote Link to comment Share on other sites More sharing options...
simonb Posted January 7, 2020 Share Posted January 7, 2020 You can actually re-solder it. Use a standard 25W electrical soldering iron, and clean up the tag and rear window strip with wire wool. Tin both the components and then solder together. The glass is toughened and designed to get warm - you will only need a few seconds to heat up thin metal strip on the glass. Epoxy, even metal loaded is unlikely to work as they won't be conductive enough. 1 Quote Link to comment Share on other sites More sharing options...
